User Menu Configuration problem
May 31st, 2007
I am trying to configure a menu to be selected by a user on my network thrugh the use of a menu.however,I have a problem getting it to work.Whenever I telnet into the router,the menu does not display.below is the conf.
menu branchadmin prompt ^$ Please Select an option ^$
menu branchadmin text 1 show interface
menu branchadmin command 1 show interface
menu branchadmin txt 2 show line
menu branchadmin command show line
menu branchadmin txt 3 exit
menu branchadmin command 3 exit
username user1 nopassword privilege 10
username user1 noescape autocommand menu branchadmin
privilege exec level 10 menu branchadmin
privilege exec level 10 show interface
privilege exec level 10 show line
Am I missing something?
Help will be appreciated ASAP
Overall Rating: 5 (1 ratings)
dominic.caron Sun, 06/03/2007 - 16:15
  • Silver, 250 points or more
Did you configure the...
autocommand menu "menu_name"
on your vty interfaces ?
ggilbert Mon, 06/04/2007 - 07:42
  • Cisco Employee,
Yahaya,
What dominic said should do the trick.
Cheers,
Gilbert
