wae design
May 31st, 2007
we have an inter-vlan network with the L3 switch on the core and a couple of at&t routers on the edge. According to the cisco wae implementation doc, they only go over the wae design, where the core switch is a layer 2 switch. Should we take the same approach as far as the wae design is concern (namely, 2 vlans and the redirection/interceptions on the edge routers) for the layer 3 switch as for the layer 2 switch?
thanks.
_Greg
Zach Seils Fri, 06/01/2007 - 13:41
Greg,
Do you have a topology diagram we can take a look at?
Zach
