IPCC IVR
May 31st, 2007
Hi,,
I installed cisco CRS 4.0(4)_Build140 in my lab envirnment and i would setup an IVR, I had managed to do that.
so i can call IVR from my lab IP Phone and the aa.aef is working fine, but when i tried to call from PSTN the prompt message is fine but when i press 0 for AA i got "the phone no you are trying to reach is currently out of service".
how to solve this issue.
regards
Zin.Karzazi Fri, 06/01/2007 - 03:30
  • Silver, 250 points or more
Seems like an CSS/Partition issue, did you check that? GW CSS and CTI-Port CSS include your Phone Partition?
osamaokok Fri, 06/01/2007 - 11:36
Thanks for you reply, i'm implementing any partition nor CSS in my lab envirunment, CTI port i'm not sure how to do that. i just wanna basic ivr system.
regards
osamaokok Fri, 06/01/2007 - 11:50
regards
Chris Deren Fri, 06/01/2007 - 16:45
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
What do you mean press 0 for AA?
How is the call flow?
Do you get the menu and then press 0 for operator? If so is the operator parameter (variable) defined as valid DN?
Chris
osamaokok Sat, 06/02/2007 - 01:46
yes i get the menu from my DN (when i call 399 which is my trigger no. in Jtapi subsystem)i also used aa.aef in the script managment and i point the operator parameter to a valid DN.
Now:
When i call 399(my ivr no.) from any DN (ie. 310) i can get the menu and i can call the operator or any DN.
I used the same IVR No. (399) as a connection plar opx in my h323 gateway, i can get the menu but when i press 0 for operator or any DN i got "the phone no you are trying to reach is currently out of service".
regards
Chris Deren Sat, 06/02/2007 - 15:58
  • Hall of Fame,
This does sound like a CSS/Parition issue, so the phones DNs do not have paritions assigned to them, they are assigned to Partition?
Chris
