http to https redirection
Answered Question
May 31st, 2007
I have a sceanrio where I need to redirect to https from http. For example, if customers enter
http://www.sm.com should be redirected to https://www.sm.com
http://www.sm.com/portal -> https://www.sm.com/portal
The first redirect works fine. But the second redirect which is for the portal site works only when customers enter https://www.sm.com/portal. If customers enter http://www.sm.com/portal, they get redirected to https://www.sm.com due to the service redirect-sm which looks for the wildcard match "/*". I tried to be more granular with the redirect but nothing seems to work. Here is the config.
SSL termination is done on the CSS and the servers are listening on port 80. I have the following config
service smweb01-80
port 80
keepalive frequency 10
ip address 10.20.20.11
keepalive type http
keepalive port 80
active
service smweb02-80
port 80
keepalive type http
keepalive port 80
ip address 10.20.20.12
active
service redirect-sm
type redirect
keepalive type none
ip address 1.1.1.1
no prepend-http
redirect-string "https://www.bsm.com"
active
service redirect-sm-portal
type redirect
keepalive type none
ip address 1.1.1.1
no prepend-http
redirect-string "https://www.sm.com/portal"
active
service ssl_serv1
type ssl-accel
slot 3
add ssl-proxy-list sm
port 443
keepalive type none
active
content sm-redirect
add service redirect-sm
vip address 10.10.16.12
protocol tcp
port 80
url "/*"
active
content sm-redirect-portal
add service redirect-sm-portal
protocol tcp
port 80
url "/portal*"
active
content sm.com-decrypt
vip address 10.10.16.22
add service smweb01-80
add service smweb02-80
protocol tcp
port 81
active
Correct Answer by Gilles Dufour about 9 years 9 months ago
http://www.cisco.com/en/US/products/hw/contnetw/ps789/products_configuration_example09186a00801de8d6.shtml
in the url above, you'll see the 3 methods to do redirect.
You need to use option #3, with the command 'domain'.
Gilles.
Overall Rating: 5 (1 ratings)
mchockalingam Fri, 06/01/2007 - 04:14
Gilles,
I used this link to configure the redirect service. But I am not really understanding the difference between domain and a redirect string.
I modified the following redirect service to use domain instead of a string but still http://www.sm.com/portal does not redirect to https://www.sm.com/portal but instead it redirects to https://www.sm.com
type redirect
keepalive type none
ip address 1.1.1.1
no prepend-http
active
mchockalingam Mon, 06/04/2007 - 09:44
The following config worked.
service redirect-sm
type redirect
keepalive type none
ip address 1.1.1.1
no prepend-http
domain https://www.bsm.com
active
type redirect
keepalive type none
ip address 1.1.1.1
no prepend-http
active
Gilles Dufour Mon, 06/04/2007 - 09:58
the domain command will only change the hostname and leave the url unchanged.
The redirect-string will change both the hostname and the url.
Gilles.
