Call transfer problem
May 31st, 2007
I am using Call Manager ver 4.0(2a)sr1.
VG is Cisco 2811 with software ver c2800nm-ipvoicek9-mz.124-13a.bin
On VG there is
dial-peer voice 10 voip
preference 1
destination-pattern 53..
voice-class h323 1
session target ipv4:x.x.x.x
dtmf-relay h245-alphanumeric
with
voice class h323 1
h225 timeout tcp establish 3
When a call comes directly from outside everything looks fine.
When the call is answerd from one local number and oprator want to transfer it to other problem starts.
The other phone rings, but when someone answer the call it is disconnected.
Zeljko
gogasca Sat, 06/02/2007 - 21:37
Do you have MTP enabled in the H323 GW configuration?
If so which type of MTP? HW or SW (IPVMS)
Check regions
Based on the dial-peer you are using G729 (used when no codec|voice class is configured)
When you answered the phone can you park, conference that call?
The last destination is in the same location?
Happens for all models?
kuturovac Mon, 06/04/2007 - 02:58
I do not have MTP enabled
I will check the regions
When I answered the phone I can not park call.
Displayed message is "Can not complete conference call". It is same message "Can not complete call transfer".
The last destination is on same location.
They use 7912 phone, but we tried with Cisco IP communicator it is the same.
Zeljko
