CM5.1 MCS 7845H NIC Teaming
Jun 1st, 2007
How to setup NIC Teaming on MCS7845H for CM5.1?
clachoi Fri, 06/01/2007 - 06:41
Here is a link that show how:
In order to enable NIC teaming, complete these steps:
Secure shell (SSH) or log on to the console directly.
Enable it from the command line on the server.
Set network NIC failover enable.
Reboot the cluster.
Issue the show status command.
Issue the show network failover command.
Note: NIC teaming is only supported for fault tolerance and not load balancing.
