FXO dial forwarding delay
Jun 1st, 2007
We have 4FXO ports on 2811 and CM5.0...FXO ports are directly connected to TELCO. 2811 is a H323 gateway.
When someone calls from outside, he hears two rings. After that fxo forwards the call to an ip phone. It means ip phone rings n times, but caller hears the ring n+2 times. How can i solve this issue? I want the fxo port to forward the call immediately...But how?
voice-port 0/2/1
cptone GB
timing hookflash-out 50
connection plar 88(an ip phone)
vmoopeung Thu, 06/07/2007 - 12:08
  • Bronze, 100 points or more
Seems like FXO is looking for caller-id.
Check with the phonecompany if they are sending caller-id. If they are not sending caller-id removed the caller-id command from the voice-port.
router.mou Fri, 06/08/2007 - 01:50
hi,
fxo port will wait for at least 1 ring to pickup the phone then plar to ur ip phone.
so in between the caller may wait for n+2 ring times.
you may check the command "ring number" , which defines the waiting time of a fxo port. and the default number is 1.
regards
steve
