Configuring Virtual links in Cisco 3550 switch
Jun 1st, 2007
I am using a CISCO 3550 Multilayer switch with the
IOS version 12.1(11)EA1. I am configuring
Virutal link with the following commands :
cisc0(config)#router ospf 10
cisco(config-router)# area virtual-link authentication null dead-interval 40 hello-interval 10 retransmitt-interval 5 transmit-delay 2
But the DUT does not make as its neighbour. The area is a transit area.
Kindly let me know whether any other configuration is required
j-block Fri, 06/08/2007 - 06:55
A VLAN interface created by using the interface vlan vlan_id global configuration command and by default a Layer 3 interface.
royalblues Fri, 06/08/2007 - 11:20
Can you post a brief n/w topology?
What do you see when you do a debug ip ospf adj?
srue Fri, 06/08/2007 - 12:00
is the router-id ? that portion of the command needs to be the router-id, not necessarily the IP address.
