are AP1242 in workgpbridge mode roaming capable ?
a.diot
hi all ,
i have aps 1242 with wireless client associated and an ap1242 in workgroup bridge mode associated too , can the ap in workgrp mode roam between different AP1242 ? if yes is there some special conf needed ?
normaly the client decide wich ap to associate with , does ap in workgrp have the same capacity ?
some sample or link will be very helpfull
thanks
Rob Huffman
Hi Alain,
Try this out;
Q. How do I configure my AP acting as WGB to dynamically switch between parent access points based on signal reception?
A. Use this command in order to configure the Workgroup Bridge as a mobile station:
ap(config)#mobile station
When you enable this setting, the Workgroup Bridge scans for a new parent association when it encounters a poor Received Signal Strength Indicator (RSSI), excessive radio interference, or a high frame-loss percentage. With the use of these criteria, a Workgroup Bridge configured as a mobile station searches for a new parent association and roams to a new parent before it loses its current association. When the mobile station setting is disabled, the default setting, the Workgroup Bridge does not search for a new association until it loses its current association.
From this good doc;
http://www.cisco.com/en/US/docs/wireless/access_point/12.3_7_JA/configuration/guide/s37hot.html#wp1041626
Hope this helps!
Rob
thanks a lot Rob
