2950 image naming
Answered Question
Jun 1st, 2007
  • Purple, 4500 points or more
I was looking at the 2950 images , under current it says the latest is 12.1.22EA9 . Then if you look under the previous image colummn it says 12.1.22ea10 . Can anyone explain why this would be, how can 12.1.22ea10 be a previous image to 12.1.22ea9. Seems like 12.1.22ea10 would be the latest current version . I think it is a webpage miscue as the publish dates put the ea10 version later than the ea9 version.
Correct Answer by mohammedmahmoud about 10 years 4 weeks ago
Hi Glen,
Yes its a sort by name error, i've seen this before, as if you do sorting by name 10 is before 2, no doubts the 12.1(22)EA9 is older than the 12.1(22)EA10, the website guys should find a work around.
HTH,
Mohammed Mahmoud.
Overall Rating: 5 (1 ratings)
Correct Answer
mohammedmahmoud Fri, 06/01/2007 - 04:10
  • Green, 3000 points or more
Hi Glen,
HTH,
Mohammed Mahmoud.
glen.grant Fri, 06/01/2007 - 05:16
Thanks, thats what I thought just wanted to verify before downloading .
