configuration PAgP - Port Aggregation Protocol
Jun 1st, 2007
I have two switches 3550 WS-C3550-48-SMI with the versions of IOS Version 12,1 (13) EA1, Version 12,1 (19) EA1c had been added the interfaces fa0/38, fa0/39 and one of switches and in the other switch was configured the interface fa0/44, fa0/43 both in protocol PAGP with way desirable in each one of the interfaces in switches. These interfaces will go to be connected two pairs of radio that only work in way bridge, when the two pairs of wireless are connected the interface only drip a pair of wireless in the unit that I am, in the other unit do not only obtain to give ping in the other pair of wireless the same happen with the staff of the other unit, analyzing the interfaces see that fa0/38 input packets and fa0/43 output packets, only I only see also that fa0/39 and fa0/43 receives input packets and output packets normal. desire to receive an aid so that fa0/38, fa0/43 receives input packets and output packets normal. all interfaces are in up normal and green of link ok.
glen.grant Mon, 06/04/2007 - 04:40
The config on the ports looks correct , try using channel-group 5 mode desirable non-silent" command and see if that does anything .
