CUE direct transfer to VM with no E164 option
Jun 1st, 2007
I would like to setup direct transfer to voice mail in CUE.
I'm already using the E164 for DID assigment so that's not an option. Looks like I will have to go with a translation rule my dial plan is 3 digits begining with 1.. and the E164 number begins with 834221....
Can you help with an example.
thanks
Armando
Overall Rating: 5 (1 ratings)
aramos17428 Fri, 06/01/2007 - 05:48
i figure it out. 8 plus the 3 digit extension.
voice translation-rule 1
rule 1 /^8\(.*\)/ /\1/
voice translation-profile extra_extn
translate redirect-called 1
dial-peer voice 1 voip
translation-profile outgoing extra_extn
preference 1
destination-pattern 6000
session protocol sipv2
session target ipv4:10.66.81.94
incoming called-number .
dtmf-relay sip-notify
codec g711ulaw
no vad
ephone-dn 6 dual-line
number 81..
call-forward all 6000
Armando
