Synchronize NTP of a computer XP with a Router 2500
Jun 1st, 2007
What I must make to synchronize NTP of a computer XP with a Router 2500. Annexed, commando that I execute from XP and error, "sh ver" of router, and configuration NTP in router
C:\>net time \\
System error 53 has occurred.
The network path was not found.
Sistema Operativo
Windows xp
IOS (tm) 2500 Software (C2500-DS-L), Version 11.2(3)P, SHARED PLATFORM, RELEASE
Copyright (c) 1986-1996 by cisco Systems, Inc.
Compiled Tue 31-Dec-96 17:25 by tamb
Image text-base: 0x030358E4, data-base: 0x00001000
ROM: System Bootstrap, Version 5.2(8a), RELEASE SOFTWARE
ROM: 3000 Bootstrap Software (IGS-RXBOOT), Version 10.2(8a), RELEASE SOFTWARE (f
pzr-josejps01 uptime is 20 weeks, 6 days, 23 hours, 6 minutes
System restarted by power-on at 09:56:24 GMT-4 Fri Jan 5 2007
System image file is "flash:80135103.bin", booted via flash
cisco 2500 (68030) processor (revision N) with 2048K/2048K bytes of memory.
Processor board ID 05646962, with hardware revision 00000000
Bridging software.
X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
1 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read ONLY)
xxxxxxxxx#sh ntp status
Clock is synchronized, stratum 6, reference is
nominal freq is 250.0000 Hz, actual freq is 250.0019 Hz, precision is 2**19
reference time is CA0A974F.4E2BC650 (09:02:07.305 GMT-4 Fri Jun 1 2007)
clock offset is -0.3640 msec, root delay is 86.61 msec
root dispersion is 57.56 msec, peer dispersion is 0.67 msec
ntp authentication-key 2807200 md5 xxxxxxxxxxxx 7
ntp authenticate
ntp trusted-key 2807200
ntp clock-period 17179732
ntp source Loopback0
ntp peer
