ASA 5505 disable ping reply
Jun 1st, 2007
when my pix failed I switch over rapidly to a asa 5505
two of my external ip address say 1.1.1.x and 1.1.1.y are replying to ping replies from the internet. one address is used in my outside interface and the other is used in my route outside command
interface Vlan2
nameif outside
security-level 0
ip address 1.1.1.x 255.255.x.y
te outside 0.0.0.0 0.0.0.0 1.1.1.y 1
Jon Marshall Sun, 06/03/2007 - 00:22
For your asa you need to deny ping replies from the outside interface. Attached is a link that explains how the asa responds to ping and how to deny it
http://www.cisco.com/en/US/products/ps6120/products_command_reference_chapter09186a008063f9fd.html#wp1631466
As for the 1.1.1.y that is presumably the upstream router from your asa. There is nothing you can do on the asa to stop this responding to pings. You need to log onto the router and use an access-list to prevent this happening
The router might be managed by your ISP. If so you need to talk to them but they may well require it for troubleshooting purposes.
Jon
