Upgrade IPCC Enterprise from 7.0 to 7.1(4)
Jun 1st, 2007
I had problems when i tryied to upgrade IPCC Ent. from 7.0 to 7.1(4).
I received message that the database can not be updated.
The error in logs was:
2007-05-08 19:16:50 [Information] Running command: C:\icm\bin\upgrade.exe -d fibcc_sideA -dt logger -i fibcc -dr reset
2007-05-08 19:16:51 [Error] C:\icm\bin\upgrade.exe failed with error 0x1 (1): Incorrect function.
2007-05-08 19:16:51 [Error] An error occurred while udpating the the schema for the database fibcc_sideA.
Logs of the database operation can be found in C:\Temp\<hostname>_fibcc_sideA.log
Does anyone have the same problem and is there some decision for that problem?
Chuck Smith Sun, 06/03/2007 - 06:17
Read the release notes. Most probably you will have to upgrade to 7.1(2) before goign to 7.1(4)
ayordanov77 Mon, 06/04/2007 - 00:29
Thanks for the tip.
I have the thoughts in my mind, but i was not sure about it.
I will make a test on the test IPCC that i installed and i hope that it will works.
When i finish the test i will post the result.
kent.roberts Tue, 06/05/2007 - 18:50
When I updaed 7.x I installed 712 first, then went to 714. Don't forget to update ctios and cad (if you use them) The must be run with the proper version. FYI the backout/removal of 712 to make the system back to 7.0 failed.
