Testking version ?
Jun 1st, 2007
Can any one tell me which version is going on nowadays for CCNA exam. i am looking the latest version from testking dumps.
regards,
m.khan
jrensink78 Fri, 06/01/2007 - 08:27
Don't use brain dump sites. They cheapen the certification system and you don't really learn the material like you should.
I would suggest actually picking up a few books that have practice exams and simulations as reinforcing materials. Study the books and practice the exams once you have a handle on the material. Then you can see where you are strong and where you are weak so you can focus your studies even better.
vmzyece1977 Sun, 06/03/2007 - 14:37
I used to have one testking stuff, trust me , its all worst. I then bought the actual cisco routers and making a good progress. Its worth it. Testking will never help you when you are in the field.
