Help...routing works intermittenly
Jun 1st, 2007
I'm new to Cisco VPN so I might be asking some dumb question but here goes. I have the vpn 3000 concentrator configured not sure correctly or not but I was able to connect with the VPN Client successfully. The problem is sometime I'm able to ping and tracert to the destination address by IP or hostname and sometime can't using IPsec/UDP. It seems to be working fine with Microst client using PPTP. Also, I noticed after disconnectine with PPTP and connecting with the Cisco client everything work fine. Any help is appreciated.
