06-01-2007 08:27 AM - edited 03-11-2019 03:23 AM
With a PIX 501 running 6.3(4) connecting to the ISP via PPOE with a static IP, What command syntax can I use to create a static NAT translation from that out side IP to a internal IP For the use of incoming Web traffic, email and things like that.
I have done it with a multiple IP but never done it with just the 1 ip on the outside interface.
thanks!
Brandon
06-01-2007 10:42 AM
Configure static port redirection using the interface statement
static [(internal_if_name, external_if_name)] {tcp|udp} {global_ip|interface} global_port
local_ip local_port [netmask mask]
ex:
static (inside, outside) tcp interface 80 192.168.1.10 255.255.255.255 80
Chad
Please rate if helpful.
06-01-2007 10:46 AM
Chad, just a little typo :)
static (inside, outside) tcp interface 80 192.168.1.10 80 netmask 255.255.255.255
06-01-2007 04:35 PM
ok thanks guys will try this over the weekend
