enable spanningtree portfast on switch for AP1200
network_team
Hi do i enable spanning tree portfast on a switch connting to a ap1200 my current configuration is:
interface FastEthernet0/20
description Wireless_2_W_1
switchport mode trunk
i am getting a lot of flapping and was wondering if this could help
5 Replies 5
scottmac
Level 10
Level 10
I don't think that portfast works with trunk ports, only access ports ... perhaps that's part of the problem.
STP will normally keep a port down for ~55 seconds, once it's up, it's up....until the other end drops (powers down, for example)or you reset / power-cycle the switch.
What is the timeframe of the flapping cycle how long down, how long up)?
Do the logs give you any error mesages?
What error messages do you see at the consoles of the AP and switch?
Let us know, or post 'em ....
Good Luck
Scott
Hi these are the message i get on the core switches
24w2d: %C4K_EBM-4-HOSTFLAPPING: Host 00:16:6F:42:8A:33 in vlan 22 is flapping between port Gi2/18 and port Gi2/5
This i drill down to the access switch where the wireless device is attached: But this has no error the erros are seen on the cores above. No errors on the ap just core switches Hostflapping
Is this happening on lots of wireless client MAC addresses or just one?
Do you have more than one access point?
I have seen this behaviour when the client has bridged his Ethernet and Wireless adapters together, it actually caused a loop in the network and a broadcast storm ( The APs were not Cisco ).
It might also happen if there are two access points on the same channel, the client may send one conversation via one AP, and others through the second AP.
** Please Rate posts if helpfull **
mscherting
This is typical of what I use:
interface GigabitEthernet3/46
description Wireless AP76
switchport access vlan 177
switchport trunk native vlan 177
switchport trunk allowed vlan 113,177,190,814
speed 100
duplex full
spanning-tree portfast trunk
spanning-tree bpduguard disable
end
Depends too on whether the switch supports dot1q trunking natively. The 4503 switch in this example doesn't. 2950s do.
you will get this if you have mobile wireless clients as they move between APs, on on the Switch interface the APS are connected to I put the following command to supress these messages
no logging event addr-flap
Richard.
