dot1p ( CoS) frames monitor session
Jun 1st, 2007
Hello all,
i'm trying to get the dot1p tagged frames on my wireshark , these frames are going out of my 440x controller that is connected through a trunk to my 3750 switch. When I enter the following CLIs:
SW-3750-2(config)#monitor session 1 source interface gigabitEthernet 1/0/25
SW-3750-2(config)#monitor session 1 destination interface gi 1/0/1 SW-3750-2(config)#$sion 1 destination interface gigabitEthernet 1/0/1 ?
, Specify another range of interfaces
- Specify a range of interfaces
encapsulation Set encapsulation for destination interface
ingress Enable ingress traffic forwarding
my monitoring station receive frames untagged in the wireshark. Do I need to change the registry of my LAN adapter to see the dot1p coppied frames?
Thanks in advance for your help!
Best ,
Overall Rating: 3 (1 ratings)
dsweeny Fri, 06/08/2007 - 07:01
Replace the 'switchport voice vlan dot1p' command with the 'switchport voice vlan x'command where 'x' is the vlan designated for voice traffic.
