L2TPV3 and access-lists
Jun 1st, 2007
Hi.
I have configured a L2TPV3 tunnel between two routers and have got traffic flowing through the tunnel OK. I now want to stop BPDU's from going across the tunnel. Is there anyway I can do this?
The basic config from my routers is below:
Router 1
pseudowire-class cte
encapsulation l2tpv3
ip local interface FastEthernet0/1
interface FastEthernet0/0
desc layer 2 only
no ip address
duplex full
speed 100
no cdp enable
xconnect 10.64.10.1 pw-class cte
desc L2TPv3 routed interface
ip address 172.16.10.1 255.255.255.252
duplex full
speed 100
router eigrp 1
network 172.16.0.0
no auto-summary
Router 2:
desc layer 2 only
no ip address
duplex full
speed 100
no cdp enable
xconnect 172.16.10.1 pw-class cte
ip address 10.64.10.1 255.255.255.0
duplex full
speed 100
router ospf 1
network 10.64.10.1 0.0.0.0 area 0
b.hsu Fri, 06/08/2007 - 09:21
  • Silver, 250 points or more
L2TPv3 uses a directed Control Channel session between edge routers for creating and maintaining connections. Forwarding occurs through the use of IP packet forwarding between two edge devices. An IP header and the L2TPv3 header are used to forward packets between routers. The external header is an IP header that routes tunneled packets over the IP backbone to the egress Provider Edge (PE) device.
If you want to know more please click following URL:
http://www.cisco.com/en/US/products/sw/netmgtsw/ps4748/products_user_guide_chapter09186a00803537df.html#wp137953
