06-01-2007 11:25 AM - edited 03-05-2019 04:26 PM
is it possible to update the ios via the console port? If so can you point me in the direction of some documentation or how-to do it?
Solved! Go to Solution.
06-01-2007 11:41 AM
You can:
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml
but it takes forever. You're better off consoling-up and then connecting a crossover from an ethernet port to your pc.(I assume this is a router. If it's a switch you don't need a crossover) Then run a TFTP server on your pc.
HTH,
Paul
06-01-2007 11:41 AM
You can:
HTH,
Paul
06-01-2007 11:54 AM
Thanks for your reply. the switch will not pass POST so i can't connect via ip to anything, only got the console port to work with. I got the xmodem copy working.
