ICND
Jun 1st, 2007
  • Bronze, 100 points or more
I took my ICND today and failed by about 25 points. I beleive I know the questions I messed up. What are the chances of me getting the same test when I take it next time?
Thanks!
leslieisaac Thu, 06/28/2007 - 07:13
Was there much ISDN, DDR and Frame Relay on the test?
I heard that there is alot of focus on OSPF, switching and a little WAN.
Are ACLs covered again in the this test?
Leslie,
Each test is different, but ISDN, DDR and Frame Relay are valid topics. I didn't spend a lot of time on ISDN & DDR, but did work with Frame Relay on a network simulator (Cisco Press) before taking the test. ISDN & DDR I knew enough to configure a SPID and set up dialing.
I spent more time to be honest on Wild Card Masks, ACLs, Spanning Tree, VLANs, NAT/PAT and the Routing Protocols (RIP, IGRP, OSPF and EIGRP).
There were questions on all of the above, including ISDN, and Frame Relay.
ciscomoderator. Mon, 07/16/2007 - 13:05
I wouldn't expect the same exam again at all. These exams are taken really seriously. If you think you know what questions you missed, I would suggest, just studying extra hard on those.
Cisco Moderator
