jreekers Sat, 06/02/2007 - 17:51
  • Cisco Employee,
Hi Zhenning.
Currently, there is no way to disable the floating toolbar other than to disable popups.
In ASA 8.0, we will have the capability to disable the floating toolbar.
-Joe
mstreet Mon, 09/24/2007 - 03:50
You can disable the floating toolbar. I finally got this working so thought I would share with you how to do this.
You can use APCF (Application Profile Customization Framework) to do this. It is documented (somewhat) here: http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide
Here's what to do:
cut and paste this xml script below into notepad and save as notoolbar.xml
1.0
Do not inject toolbar for all pages
tftp this into the flash on your asa box
to disable the floating toolbar in the webvpn service, connect to the firewall and configure this:
webvpn
apcf flash:/notoolbar.xml
I have tested this in v8.0 and it works great. I haven't tried this in v7.2 but it's in the manual so I expect it will work there also.
cheers
Mike Street
nwlogical Tue, 10/05/2010 - 08:37
How do I set this for only one site.   I have two sites on the asa as such:
site1.hhch.com
site2.hhch.com
I would like it to only disable the toolbar for site 2 how do I go about that?
