Configuring ISDN 2600 - 2600
Jun 1st, 2007
I'm setting up a CCNA lab and have two 2600 routers with ISDN (WIC-1B-S/T) interfaces. Does anyone know what cables and configuration settings I would need to setup an ISDN connection between the two routers in my lab environment? Any help would be appreciated. Thanks.
Riley
paolo bevilacqua Fri, 06/01/2007 - 12:54
  • Hall of Fame,
    Founding Member
you cannot connect ISDN BRI back-to-back with just cables. You will need a small ISDN BRI emulator with at least two ports. There is more than one maker for these, try looking with the leading search engine.
