Divorce Callmanager from AD
Jun 1st, 2007
Does anyone have a tips/tricks or instructions on how to do this? Our AD environment is not very stable and we would like to migrate from AD to DC directory.
Thanks in advance.
ansalaza Mon, 06/04/2007 - 16:48
Hello Charles,
Its easy, just run the AD plugin one more time.
There would be an option to remove the integration.
The only caveat would be that you can not migrate the users...once you are using DC Directory, you would see (in Global Directory) the users that you previusly had before integrating with AD.
charlesdf22 Tue, 06/05/2007 - 04:56
Is there some trick or "undocumented" process to get the data out of AD or at least some type of replication?
