BGP Load Balancing/Sharing to single homed ISP
Jun 1st, 2007
I am trying to work out how to config load balancing/sharing using BGP to a single homed ISP.
I have to CE routers (on the same AS) connecting to two separate PE routers (on the same AS) with 20M CDR PVC?s over a STM-1 links.
BGP Configs on the CE?s are below. Please can you advise what I can do to ensure that outbound traffic from the site is load shared/balanced. Also if you feel that there is any invalid config below, please can you let me know.
I would really appreciate your help.
router bgp 65500
no synchronization
bgp log-neighbor-changes
network 10.126.0.0 mask 255.255.0.0
network 10.126.65.0 mask 255.255.255.128
network 62.252.64.19 mask 255.255.255.255
network 81.144.240.87 mask 255.255.255.255
network 81.144.240.88 mask 255.255.255.255
network 137.213.248.0 mask 255.255.255.252
network 172.27.6.32 mask 255.255.255.224
network 172.27.6.128 mask 255.255.255.224
network 172.27.6.196 mask 255.255.255.255
network 172.31.0.0 mask 255.255.255.224
network 194.70.153.99 mask 255.255.255.255
network 217.140.43.88 mask 255.255.255.248
aggregate-address 10.126.64.0 255.255.248.0 summary-only
neighbor 10.126.65.3 remote-as 65500
neighbor 10.126.65.3 timers 5 15
neighbor 10.126.65.137 remote-as 65500
neighbor 10.126.65.137 description Scnm-r-cdif-02
neighbor 10.126.65.137 ebgp-multihop 4
neighbor 10.126.65.137 update-source Loopback0
neighbor 10.126.65.137 timers 5 15
neighbor 81.144.17.111 remote-as 2856
neighbor 81.144.17.111 description BT PE Router
neighbor 81.144.17.111 ebgp-multihop 3
neighbor 81.144.17.111 update-source Loopback0
neighbor 81.144.17.111 default-originate
neighbor 81.144.17.111 timers 5 15
default-metric 1
no auto-summary
router bgp 65500
no synchronization
network 10.126.64.0 mask 255.255.240.0
network 10.126.72.0 mask 255.255.248.0
network 10.126.72.0 mask 255.255.254.0
network 10.126.72.0 mask 255.255.255.0
aggregate-address 10.126.72.0 255.255.248.0 summary-only
neighbor 10.126.65.2 remote-as 65500
neighbor 10.126.65.2 timers 5 15
neighbor 10.126.65.138 remote-as 65500
neighbor 10.126.65.138 description Scnm-r-cdif-01
neighbor 10.126.65.138 ebgp-multihop 4
neighbor 10.126.65.138 update-source Loopback0
neighbor 81.144.17.52 remote-as 2856
neighbor 81.144.17.52 description BT PE Router
neighbor 81.144.17.52 ebgp-multihop 3
neighbor 81.144.17.52 update-source Loopback0
neighbor 81.144.17.52 default-originate
neighbor 81.144.17.52 timers 5 15
no auto-summary
Overall Rating: 4 (1 ratings)
