Voip Router
Jun 1st, 2007
We want to connect our two stores via voice over IP. We have a pri line coming in with 23 lines. Which routers would someone suggest for both ends of the system. We are using Road Runnr Business Class 7 down and 2 up and we will also be passing data through the same routers
Paolo Bevilacqua Fri, 06/01/2007 - 17:05
A minimum of 2801 will do. With CCME you can connect directly the IP phones or the existing PBX for the migration, and a variety of data interfaces, like the dual-T1 that can be used for voice and data simultaneously. You will need PVDM2 DSP card to support all the simultanous conversation that you plan to have on the PRI.
