Load Balance in router ethernet interfaces
Jun 1st, 2007
Hi guys,
I have a cisco 2800 with 2 ethernets.
How can i configure same ip on both, plug one in my first switch and second ethernet in second switch and both do a load balance and fail over ?
Thanks.
Fred
Anand Narayana Fri, 06/01/2007 - 22:42
  • Silver, 250 points or more
implement HSRP that is the best solutions to load balance.
Amit Singh Fri, 06/01/2007 - 22:51
  • Cisco Employee,
Anand,
You can not implement HSRP on a single router interfaces. Original poster is looking for load-balancing between the same router's ports.
Please see my post below for this :
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=LAN%2C%20Switching%20and%20Routing&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1ddea6a7
HTH,Please rate if it does.
-amit singh
fred_m Sat, 06/02/2007 - 05:59
Amit,
Your tip is not my case.
Let me explain better.
I have two switches cisco and all of my servers have two NIC's. I plug each NIC on differnt switch, but i need do a trunk link between because i have only one inteface to my route.
So i want plug eth0 router interface in switch A and eth1 in switch B and remove this trunk.
Both eth0 and eth1 have same ip address.
If one of switches stop to work my network isn't impacted.
Thanks.
Fred
mohammedmahmoud Sat, 06/02/2007 - 06:04
  • Green, 3000 points or more
Hi Fred,
Amit's suggestion is almost your only chance, as you can't have 2 Ethernet interfaces with the same IP subnet on a single router.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
fred_m Sat, 06/02/2007 - 06:11
Mohammed,
I thinked that exist some way like HSRVP to solve this question.
Thanks.
Fred
mohammedmahmoud Sat, 06/02/2007 - 06:15
Fred,
No, you can not implement HSRP on a single router, and further more you can't use the same IP (or even 2 IPs from the same IP subnet) on 2 different interfaces on the same router, and thus Amit's suggestion is almost your only choice.
HTH,
Mohammed Mahmoud.
