Transparent Firewall Configuration
Answered Question
Jun 2nd, 2007
  • Bronze, 100 points or more
When configuring a transparent firewall - is it necessary that the two firewall interfaces be connected to 2 different vlans .
What if i am using two switches , one on either side of the firewall which are not interconnected ? Do I still need to use vlans ???
Vikram A
Correct Answer by oabduo983 about 9 years 10 months ago
No you do not need to configure vlans in this case, just make sure there is no direct link between those two switches and there is no form of vlan or vtp communication between them...
Please rate if this was helpful!
Overall Rating: 5 (1 ratings)
Correct Answer
oabduo983 Sun, 06/03/2007 - 12:53
vikram_anumukonda Sun, 06/03/2007 - 19:53
Hi , Thanks for the reply - it answered my question.
-Vikram
