sundar.palaniappan Sat, 06/02/2007 - 13:24
Balaji,
Has the 2nd SPA worked before?
I haven't personally worked with SPA much. But, just wondering whether the combination of SPA-200 and SPA-400 in the same chassis is causing this due to either oversubscription or incompatibility.
I don't know if you already looked at this SPA troubleshooting document. If you haven't go through the troubleshooting steps and see if you can nail the problem.
http://www.cisco.com/en/US/products/hw/routers/ps368/module_installation_and_configuration_guides_chapter09186a0080440317.html#wp1082304
In addition you may want to use feature navigator tool to check for hardware compatibility.
Sundar
balajitvk Sat, 06/02/2007 - 22:02
Hi Sundar,
Thx for your response. But thrown some light on something else but useful...
Same configuration on other 7600 boxes is working fine. So i don't think it is due to incompatctibility or oversubscription....
I just do want to know what is Outserv Status on show module output which may give some idea on the same...
Rgs
