RME 4.0 multiple SyslogDefaultPurge Jobs
Jun 2nd, 2007
I've LMS 2.6 with RME 4.0.5. I tried to reschedule system jobs to assure, that system backup will be done correctly. After looking into RME Jobs I found out, that I have 3 "SyslogDefaultPurge" jobs - 1207,1021 and 1070. All three jobs are sheduled to the same time, two of them are always failing.
I cannot delete any of those jobs. When I try it, I see pop up window saying "You cannot delete system jobs", even when I'm logged under "admin" account.
Do you hava any idea what to try?
Jan Klicka
Overall Rating: 5 (1 ratings)
Joe Clarke Sat, 06/02/2007 - 08:26
This is leftover from CSCsb87660. The workaround is delete the failing jobs using the JRM jobcli:
NMSROOT/bin/cwjava -cw NMSROOT com.cisco.nm.cmf.jrm.jobcli
delete JOBID
Where NMSROOT is the path into which CiscoWorks was installed (e.g. C:\PROGRA~1\CSCOpx on Windows and /opt/CSCOpx on Solaris) and JOBID is the job ID you wish to delete.
After deleting the unwanted jobs, restart dmgtd.
jan.klicka Sat, 06/02/2007 - 09:19
Hello, Joe,
Thank you for the hint, it solves the problem.
Jan Klicka
