CME IP Phone "FILE NOT FOUND:distinctiv"
paolo bevilacqua Sat, 06/02/2007 - 10:10
  • Hall of Fame,
    Founding Member
The phones are looking for "distinctivereinglist.xml" that just like ringlist.xml defines custom rings. You can can alias this file to the ringlist you already have with the "tftp-server" command, and the phones will stop complaining.
robert.bernal Sat, 06/02/2007 - 12:38
You need that file in flash memory
1) Check if you have that file on flash mem:
dir flash:
if not :
Copy the file from tftp to flash then set the command tftp in global config like this:
tftp-server flash:DistinctiveRingList.xml
then reboot and thats all
