06-02-2007 08:30 AM - edited 03-05-2019 04:27 PM
Hello friends, I am Brazilian, sorry my english. Why tools use for stored log of problem with switches catalyst 2950 and 2960 series. I can use the tools CNA for stored logs ? They indicate other tools to monitor and to manage switches Cisco.
Bruno Santos
06-02-2007 10:06 AM
Hi Bruno,
You can use CNA upto some level.....
It is not clear from your writing that who is indicating for what??? You can use CNA for the small sized network upto 40 hard Network elements and also for limiting info. as compared with logs storing on the switches.....
Rate if it does,
Rgs
06-02-2007 02:42 PM
Thanks. So is necessary that the software CNA is open always, correctly ?
06-02-2007 08:36 PM
yeah your right, CNA should be opened always.
