The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally. New Here? Click here to learn more and get started.
Cisco Community is an active and collaborative place to learn more about our products and ask questions of peers and Cisco experts! Check out some of the most popular conversations happening right now!
Hello! Does anyone know if there's an easier way to configure and create rules that require manual entry in the FMC policy creation dashboard? We are working on a migration from the ASA which has over 300 rules and our company would also like to reca...
Our Forum Alert III Secondary Crash Net (SCN) is inoperable. I've heard the cisco cm could be configured to set up some devices to act as a ringdown, they called it a “Switch Box.” This would allow our Base Operations guys to have a work around from ...
Hello we have a local 9120axi AP with a 9800LC WLC that seems to be losing connection. The AP is in flex connect, all config looks fine: AdvancedCountry CodeUS Multiple CountriesUSStatistics Timer180CAPWAP MTU1485AP Link LatencyEnabledAP PMK Propaga...
Hi Guys, i had this problem for 8 hours now and can't seem to get it cracked... after i input the command copy xmodem: flash:c2960-lanbasek9-mz.152-7.e9.binand using the SecureCRT going to Transfer > send xmodem I get this and after that nothing happ...
HelloWe have a lot of clients getting the following error when contacting diffrent sites: ERR_SSL_PROTOCOL_ERROR, we have read that SonicWall and Palo Alto also have these problemes. Solution is to turn off "TLS 1.3 Hybridized Kyber Support" in chro...
How do I get a human at 퐃퐞퐥퐭퐚 퐀퐢퐫퐥퐢퐧퐞퐬 immediately? Customer~Service 24*7Phone assistance: One of the quickest ways to speak with a 퐃퐞퐥퐭퐚 support agent is by calling + + 1-707~833~ퟵퟬퟮퟳ✈ or+ + 1-707~833~ퟵퟬퟮퟳ✈. The phone number for 퐃퐞퐥퐭퐚 assistance is ...
How do I get a human at 퐃퐞퐥퐭퐚 퐀퐢퐫퐥퐢퐧퐞퐬 immediately? Customer~Service 24*7Phone assistance: One of the quickest ways to speak with a 퐃퐞퐥퐭퐚 support agent is by calling + + 1-707~833~ퟵퟬퟮퟳ✈ or+ + 1-707~833~ퟵퟬퟮퟳ✈. The phone number for 퐃퐞퐥퐭퐚 assistance is...
with ver6.xwhen the operation receive a call from PSTN and transfering to the internal user, on internal user phone, it shown the call from operator, we want to setup shown as the real caller, anyway to enable it?thanks
I have a doubt that how two controle planes will work in vPC and what are the real time scenarios to see the two controle planes vPC. Can any one help me to understand exactly how two controle planes works compared with single controle planes in VSS ...
Hi,Please I need an advise to determine the right NGFW based on the below requirements:- Each NGFW physical appliance should provide minimum of 240 Gbps Firewall throughput.- Each NGFW physical appliance must support minimum of 850,000 new TCP connec...
If webex is used in ubuntu 24.04 there's an apparmor error logged like this: audit: type=1400 audit(1713968367.781:343): apparmor="DENIED" operation="capable" class="cap" profile="unprivileged_userns" pid=10844 comm="CiscoCollabHost" capability=21 c...
Hey everyone, Hope you're all doing great! I'm looking to update my ACI APIC, but I'm a bit lost on where to start. My current version is pretty ancient and it's never been updated. Here's what I've got: Role Pod Node N...
Is there a tool available to convert a Check Point Security Policy to a Cisco Access Control List?The process of doing this manually would be time consuming and could result in human error
Hi, We´ve been using XRd as a way to do integration testing with our autoprovisioning platform using gnmi.This works great.However I'm currently trying to do end to end testing of the whole solution with actual traffic forwarding across the finished ...
