CME Codec Question.
Jun 2nd, 2007
Hi, im setting up a trunk CME - AVAYA
How can a revice in CME a call with codec G711ulaw, because avaya its sendme the call with that codec, and CME use G729 per default
robert.bernal Sat, 06/02/2007 - 12:47
from CME to AVAYA its working because in dial-peer I set the codec G711ulaw command like this:
Paolo Bevilacqua Sat, 06/02/2007 - 12:51
Actually CME phones uses G.711 by default, however it is also true that "dial-peer voice" uses G.729 by default so you have to set as g.711 as needed.
Now for incoming VoiP calls you will need a dial-peer voice configured with "incoming called-number" and "direct-inward-dial", do you have one ? You can reuse the same DP used for outgoing if you whish.
robert.bernal Sat, 06/02/2007 - 12:57
Thanks for reply,
Ok, so if i want to use the same this will be ok:
ext 63.. => Avaya
ext 72.. => CME
dial-peer voice 50 voip
destination-pattern 63..
session target ipv4:
incoming called-number 72..
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
Paolo Bevilacqua Sat, 06/02/2007 - 14:24
Yes. Ignore the reference about direct-inward-dial, for a moment I made confusion about a pots DP.
