2851 Router with 3 x ADSL interfaces
Jun 2nd, 2007
Hi all,
Wondering if someone can assist with a config I need to put together in the next few weeks.
Situation is this:
Cisco 2851 Router with 3 x ADSL interfaces
Reason behind the 3 x ADSL's is the following:
1 x ADSL (512k/512k) to be used for VoIP traffic
1 x ADSL (512k/512k) to be used for MS SQL traffic
1 x ADSL (8000k/384k) to be used for everything else
Each of these ADSL's will need a site-to-site IPSEC connection back to our main site (terminating on a 3rd party firewall). My question is how should I go about configuring the ADSL interfaces so that only the specified traffic types travels down the correct link?
And if you were wondering why we are looking at doing this on a 2851 it's because the 4th interface is a VIC2-2BRI, and the router is going to be doing SRST (supporting approx 60 VoIP phones).
Any suggestions/comments/example configs would be greatly apreciated.
Overall Rating: 4 (1 ratings)
bjornarsb Sun, 06/03/2007 - 02:30
  • Bronze, 100 points or more
This might be a start?
interface fastethernet 3/1
desc ** LAN interface ***
ip policy route-map Texas
ip nbar...
route-map Texas permit 10
match protocol XXX
set ip next-hop 3.3.3.3
route-map Texas permit 20
match ip protocol XX
set ip next-hop 4.3.3.5
or set interface XXX
route-map Texas permit 30
Then you have 3 different crypto-maps for
you ipsec connecitons, each applied to one ADSL interface.
BR,
Bjornarsb
gregsmales Sun, 06/03/2007 - 14:50
Thanks for your reply. I'll give this a go once I get my hands on the hardware
gregsmales Wed, 06/06/2007 - 17:11
I've started building a config for this and have struck a potential problem.
When you define each of the three crypto-map's you need to define a 'match' statement which points to an ACL. If the route-map's are matching based on protocol, how should I look at matching the crypto-map's?
Also is it possible to have a different pre-shared key for each ipsec tunnel?
gregsmales Wed, 06/06/2007 - 17:43
Also, I actually don't see 'match protocol' or 'match ip protocol' as available selections in the route-map. Do I need to turn something on like nbar or cef?
a.cruea1980 Thu, 06/07/2007 - 08:45
I'd suggest for your mapping on the crypto-maps for your router, match via protocol/ports. You know your SQL is bound to port 1433 or something like that, and it's a TCP protocol. Your VoIP will fall on certain ports and use UDP. . .make sure and include your skinny protocol in there as well.
After that, I think you can gather all the traffic that's left. . .you'd just deny the other two from the access-list you're using for your bulk traffic.
And I do believe you can have a different pre-shared key since you'll have 3 different crypto-maps. I think, but don't quote me on that.
