vista and client 5.0.00..340 error 412
bwalchez Fri, 06/08/2007 - 07:07
I think a simple reinstall may not fix the problem if the windows registry got messed up. You may need to restore the client PC to an earlier point at which the client software was installed and working properly. Also check for the latest version of the client software available.
PE-PatInBC Tue, 07/24/2007 - 15:44
Did you ever find a solution for this ? I am having the same issue. The gateway accepts VPN connections from all of my XP stations but the one with Vista just doesn't work any more.
any thoughts ?
