06-03-2007 02:37 PM - edited 03-03-2019 05:16 PM
I need link to configure Well SNA DLSW on Routers Cisco.
Solved! Go to Solution.
06-03-2007 02:46 PM
These are the configuration examples:
http://www.cisco.com/en/US/tech/tk331/tk336/tech_configuration_examples_list.html
Hope this helps, pleas rate post if it does!
06-03-2007 02:46 PM
06-03-2007 03:15 PM
How do I check Mac Address , timers and reachability ?? on Cisco routers using DLSW? If the Mac Address doesnt show using the "show dlsw reachability" command...
