IP Phone to IP Phone communictation through ASA/PIX
Jun 3rd, 2007
As I know the IP Phone to IP Phone is RTP and the port number is randam and the range is very large(16384 -32767 /UDP)
How to configue ASA/PIX to make the voice stream through firewall but not configre allow so large range port number?
paolo bevilacqua Sun, 06/03/2007 - 20:09
  • Hall of Fame,
    Founding Member
the PIX supports both SCCP and SIP "inspection" so in most situations will dynamically open the ports as necessary. Do you have CCM "inside" the PIX and you want to connect a phone "outside" ?
lllliu Sun, 06/03/2007 - 21:12
No, it's multi-sites configuration.
Each sit has it's own callmanager and have firewall between them.
The call setup is through H.323 singnal, I think it can use "inspection" fixup function. But how about the voice straem between two sites' IP phone? should I opne all udp port range or any special configuration I can do?
lllliu Sun, 06/03/2007 - 22:23
