deepagup Mon, 06/04/2007 - 07:05
No. CCM 5.X still does not support paging feature. You will have to use 3rd party to achieve the same.
Paging is a feature available in Call Manager Express
Chris Deren Mon, 06/04/2007 - 09:35
Even CM 6.0 will not include Paging, so if that is a feature you need within the next 12 months I suggest you take a look at Berbee's Informacast www.berbee.com
HTH,
Chris
