Remote Access VPN: Connecting but cannot access inside network
Jun 3rd, 2007
I have successfully created a remote access vpn on ASA5520. The Cisco Client software connects to remote ASA box and assigns the PC an IP address but I cannot access the Insode network once connected. I have enabled "sysopt connection permit-vpn" to permit VPN traffic and created an accesslist to permit traffic 2 inside network but nothing happens.
What am I missing out?
acomiskey Mon, 06/04/2007 - 05:12
  • Green, 3000 points or more
Could you post a clean config?
Do you have crypto isakmp nat-traversal?
ggilbert Mon, 06/04/2007 - 11:42
  • Cisco Employee,
Edward,
Can you make sure you have NAT exemption configured on the ASA for the network.
Send the outputs of
sh run | in nat
sh run | in ip local
sh vpn-sessiondb remote
Gilbert
yiyan Mon, 06/04/2007 - 23:21
Hey,I think u should check these UDP port:500,4500,10000,10001.
I met the same issue last time and at last I find the UDP port 10000 is not allowed in my firewall,and then the problem is fixed.
