Reverse DNS question
Jun 3rd, 2007
Dear All,
Customer reported the fault that they can not send email to AOL.com, AOL.com said that they blocked the customer email address (@xxx.com.us) as SPAM email, and suggested customer to set up reverse DNS, may i know if reverse DNS set up is the solution for this problem?
thank you,
bjornarsb Mon, 06/04/2007 - 01:05
Reverse dns is used to approve the sender.
Check its validity. Our e-mail provider does the same.
BR,
Bjornarsb
