ACE - Not able to configure Context
Jun 3rd, 2007
All,
I have configured an ACE with some contexts. I think I have configured it according to the documentation.
If I switch to a different context using the changeto command, I switch to the context, but get the following error message:
NOTE: Configuration mode has been disabled on all sessions.
Anyone has an idea how to solve this?
Thanks, Pieter-Jon Buitelaar
Gilles Dufour Mon, 06/04/2007 - 04:18
  • Cisco Employee,
Pieter,
you can only change the config on the active ACE. So, verify if you are on the active unit with the 'sho ft group det' command.
Gilles.
p.buitelaar Mon, 06/04/2007 - 04:54
Gilles,
I am running a single ACE in single mode not in FT mode.
However, after rebooting the ACE module, I was able to go into conf mode in all contexts.
Any explanation for this behavior?
Thanks for your reply, Pieter-Jon
