Switch Ports hang
Jun 4th, 2007
I am running Catalyst 5500. Recently one problem has been observed that whenever a connected devices goes OFFLINE, the port status also goes no NOTCONNECT status. BUT When the devices comes back ONLINE, port status does not changes until switch is not restarted.
Please help.
smalkeric Fri, 06/08/2007 - 09:26
  • Silver, 250 points or more
You can see summary or detailed information on the switch ports using the show port [mod_num[/port_num]] command. To see summary information on all of the ports on the switch, enter the show port command with no arguments. Specify a particular module number to see information on the ports on that module only. Enter both the module number and the port number to see detailed information about the specified port.
