7204 router e1/pri slot bridge mode configuration
Jun 4th, 2007
hai
i want to puthrough a circuit with tellabs ethernet modems one end and other end with cisco 7204 channelized e1/pri slot with bridge mode configuration
what commands shall i give on e1/pri slot ?
can any body guide me
7204 router ios ver is 12.1
with regards
manjula
Paolo Bevilacqua Mon, 06/04/2007 - 12:50
Are you trying to bridge IP ? If, so what is the reason? As you should not do that normally.
manjuladevi Tue, 06/05/2007 - 01:56
hi
i have to connect one pc through wan link to central location
i dont want to use router at remote end for single pc
i can build through lan extenders by connecting to switch at central location and remote end directly to pc
but i want to extend this wan link to channelized e1/pri at central location and bridge modem at remote end
manjula
Paolo Bevilacqua Wed, 06/06/2007 - 00:04
Before worrying about bridging you should try to have this lan extender to communicate with the router via its serial interface and PPP.
After that the configuration is generally limitited to "bridge irb" and configuring a BVI interface.
