Can you configure multilink ppp on Cisco 876 routers ISDN port.
Jun 4th, 2007
I couldn't configure ppp multilink on dialer or BRI interface in Cisco 876 with advanced security IOS.
Overall Rating: 1 (1 ratings)
spremkumar Mon, 06/04/2007 - 04:09
Can you revert back the error message which you are getting while trying to key in ppp multilink under the bri interface ?
aganguly Mon, 06/04/2007 - 04:13
No error message ; the command is not going itself. ppp multilink option (keyword) is not available under BRI or Dialer interface. Does it because this interface is ADSL over ISDN interface?
Paolo Bevilacqua Mon, 06/04/2007 - 04:10
You should be able to, please report the exact problem.
However, unless you need to place calls to multiple destinations, you can make all the configuration also directly under the bri interface.
