06-04-2007 05:04 AM
I have a customer looking for a replacement power cord for a 9216i.
We need a cord with a C15 female end with a notch in it on one end and the hooded connection C14 connector on the other.
Do we have such a cord available?
06-04-2007 10:55 AM
The hooded C14 is an IEC cable. If you look in the list you will see that No IEC cables are available for purchase.
The list of supported cables is available here -
http://www.cisco.com/univercd/cc/td/doc/product/sn5000/mds9000/9200_hig/portcabl.htm#wp1058250
You have Three options.
1. Get a pdu that matches your available power cable choices.
http://www.apc.com
2. have a custom cable made
http://www.cypressindustries.com/products/power.html
3. use an adapter - note if you do, please make sure that the cable in the middle supports the needed amperage.
http://www.stayonline.com/searchresult.aspx?categoryid=2317
If you find this helpful, please rate it.
--Colin
