RIP Broadcast
Amit Singh Mon, 06/04/2007 - 06:32
  • Cisco Employee,
Where you are getting the message. Are you trying to ping 4510 switch or where on your network. Please let us know about your toplogy.
HTH,
-amit singh
I am getting the ICMP msg as a a result of RIP Broadcast from a router that is several hops away. The ICMP msg indicates TTL exceeded. Since the RIP Broadcast has a TTL of 1, it should not travel past the 1st hop.
How then is it possible that I would get an ICMP message from a router several hops away??
