chris.lepa Mon, 06/04/2007 - 07:57
I don't know of this grid you speak about... Care to tell us what devices you are connecting?
-Chris
WFSpark50 Mon, 06/04/2007 - 08:19
Any Devices, ie switches to switches requires a straight through RG45 but switch to a router needs a crossover etc etc there is a grid which gives you the devices down the left nd across the top then in the middle it tells you which type of cable to connect each device with
jasonrandolph Mon, 06/04/2007 - 09:18
DTE to DTE = Crossover (Hub/Switch to Switch/Hub)
DCE to DCE = Crossover (PC to Router)
DTE to DCE = Straight through. (Hub/Switch to PC)
